Getting mixed answers about AC repair
blu3fan
Arizona
on my 92 xj. the ac has never worked.
system holds pressure.
turning it on. clutch engages and disengages. so the electronics work.
What I remember.
in 2007~ r12 was drained and was charged with propane.
did not blow cold. guessed compressor was bad.
drained and left empty.
10 years later. 2017 refilled with r12 and oil. still holds pressure.
so.
not really too familiar with A/C to say myself
People are telling me since the compressor might be dead and I should replace the evap core because its probly full of shards. along with the entire system
Makes sense right ?
been slowly planning on doing this.
Got an expansion valve and a dryer.
need a compressor still.
my friend whos a pretty reliable mechanic tells me just to drain the system. and throw the new parts on. telling me the evap is fine.
just do not want to trash my new compressor. but equally if I can drain flush and fill the system and be fine it would be nice.
input would be awesome.
particles are unlikely to be in the evaporator core, most likely to be in the condenser (in front of radiator) or the filter/drier. some of the compressor warranties require you to replace both. rockauto sells kits with all three.
thanks for the input.
