EKO1984
- Wichita, KS
First of all, killer forum you guys have here. My hobby is F-bodies (Camaro/Firebird), but I'm also into Jeeps. I've had a 93 XJ (2DR, 2WD, 4.0, auto) that I've used as a beater for a while. Last month that randomly died on me, so I ended up buying a 91 YJ (4.0, 5sp). But the reason I'm here is for some help on my XJ. So, hopefully you guys can add some insight. I'll just copy/paste from my posts on the F-body forum I frequent.
Pictars:
Have I found the problem? If so, should I start looking for a used engine? Thanks!
So it went down like this. Friday night I checked the fluids before I went for some Chipotlaway. I started it up to check the trans fluid and after a few seconds it stated making a high pitch squealing. Kind of like a belt but not really. It eventually went away and I shrugged it off. Acquire Chipotle. Profit. Saturday morning, I go to move it, and it's cranking but not starting. Begin troubleshooting in the apartment parking lot in the cold/wind.
Side note: It's been knocking for a while, so I've been using straight 30 weight oil.
Test 1: Fuel
Got me a nifty fuel pressure gauge with a plastic lens that melts when you get fuel on it. Super. Anyway, it had 39 psi at the rail when cranking, just like the spec says. I hit it with some starting fluid anyway. No change.
Test 2: Spark
I pull out a spark plug. It's crudded up (ash) so I replace them along with cap and rotor. No love. I can smell fuel on the plugs. I put a plug up on the valve cover so I can see it through the open hood and I get a bright blue spark both directly off the coil and off the distributor.
Test 3: Compression
Got me a nifty compression tester that looks remarkably like my fuel pressure tester. Now today it had been raining/snowing and it's currently in the low 20s and the wind is blowing about 20mph. This means I'm only checking one cylinder before I die of hypothermia. I screw it in and crank it over a good 4-5 times. 90 psi.
Hypothesis:
Using a heavier oil to keep oil pressure above the "holy crap, that's low" level combined with the cold temperatures as of late led to oil starvation of the cam bearings. The squealing was the cam bearings voicing their discontent about oil starvation. After the engine cooled, the cam seized or had mega-heavy resistance and caused the timing chain to skip a tooth. Now the cam is retarded (I only checked one cylinder), and thus the no-start condition.
What say you? Time to go car shopping?
Since the weather was nice this morning, I went out and did a compression test on the rest of the cylinders today. Something is definitely facked. Here's what I got:
#1: 75 psi
#2: 70 psi (was 90 last weekend?)
#3: 100 psi
#4: 80 psi
#5: 80 psi
#6: 110 psi
UPDATE:
Development #1: Went to NJ for 2 weeks to see family/friends over Christmas. While I was there, I bought a 91 YJ. While driving it back to KS, the fuel pump died in Troy, IL (near St. Louis). Got that fixed and decided to check the timing on the XJ that this thread is about.
Development #2: With the timing mark on the damper lined up with 0 BTDC, the rotor on the distributor is about 10-15° ATDC. Doesn't make sense to me. If anything, I would think the cam would be retarded, not advanced, if the chain slipped. Either way, valve timing is off and so is the spark timing. Looks like I found the problem, finally.
Pictars:
