zeroforhire
- Seattle
1990 Jeep cherokee
Stock AT
Ok... I know these things leak... find one leak, fix it... find another... repeat, repeat, repeat. I get it. I need help with the latest one...
It is leaking coolant. I think I have figured out where it is coming from, I just need help figuring out what to do next. It leaks enough that I have to refill the overflow bottle with about a gallon of water in the morning before I drive it.
Ok... if you are lying under the jeep (the top of your head pointing towards the rear of the jeep... lying 1 foot behind the pulleys... It is dripping from the very left corner of the oil pan. (Bottom of the block, where the block is bolted to the head???) pretty constand drip, drip, drip... even though I am parked with the jeep pointed uphill.
As I was feeling around I noticed the the bolt directly behind the corner (going back towards the rear of the jeep) is missing. Does anyone know what type of bolt that is? (size etc.) I am hoping that if I replace that, it will fix the leak. I am assuming that the gasket has expanded in that corner due to the missing bolt... I could be wrong... but then again, I could be RIGHT.
Any help I can get would be greatly appreciated. Thanks.
Stock AT
