Old December 29th, 2004, 18:06
j.minze j.minze is offline
Removing Stock Tape Deck
I have a 97 cherokee country and I'm in the process of installing a new cd player. What is the trick to removing the old tape deck and installing the new cd player. How do I get that sucker outta there? Also, on a scale from 1-10 how hard would u rate this install?
thanks,
j.minze
Old December 29th, 2004, 18:13
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
Re: Removing Stock Tape Deck
Just grab the lower corners of the trim bezel, and pull back and up. If you have an auto, move the shift lever back so the bezel clears. It's all held together with spring clips. Once the bezel is out of the way, removing the existing deck will be self explanatory....
Ivan
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old December 29th, 2004, 18:56
kubtastic's Avatar
kubtastic kubtastic is offline
http://www.installdr.com/InstallDocs...PDF/533001.pdf
could it be any easier?
Old December 30th, 2004, 19:23
jblaze5779 jblaze5779 is offline
Yeah you should probably be able to do it in about 30 min. I even used the bracket that the origional radio was in. I jsut have the basic black sony cd player I swear if fits in there so nice that it looks like it could have come stock. I had to put some spacers behind the two screws that hold the bracket in to make the radio "come out" of the dash a little more, then i could fit the clip on face bezle on to give it a really clean look.
Of course after I look it seems your 97 is a little differnet then my 91. Still it should be easy
Old December 30th, 2004, 19:52
Ok, I installed my cd player and everything but it appears as though there is a lack of support. At the top of the cd player there is a gap from the weight of the cd player pulling on the spacer. The CD player came with a metal piece that screws into the back, but im kinda unsure on how to do it to where it will provide support to the cd player. Anybody know what to do?
Thanks to everybody that posted help.
j.minze
Old December 30th, 2004, 20:02
kubtastic's Avatar
I just did this last week - New CD player, came with some sleeve of metal, and then I got a kit to install it into a Chrysler/Dodge/Jeep whatever.... It came in a purple and clear bag - so maybe you have the same kit?
I only used the two screws on the front to secure my player to the dash. But before I screwed it in, I made sure that the CD player and the plastic spacing all around it were good and tight. Did you get the kind that has all of the metal triangles? You need to bend those against the plastic housing to make it tight. Also, it came with little rails, and I used those anyway, even if they didn't exactly fit. The last little metal bracket you're talking about shouldn't be needed to get things tight.
Old December 31st, 2004, 08:57
red91's Avatar
red91 red91 is offline
On a 1 to 10 basis I give it a 2. Really easy.
Old December 31st, 2004, 14:00
Yeah, Its the same kit, and i pulled the metal things back and whatnot, but the cd player still seems to sag a little bit. There is a small gap between the the top of the black spacer and my dash. I'll figure something out though, thanks for all ur help fellas.
j.minze
using stock temp sensor for other fluids? how does this thing work? BrettM Modified Tech Discussion 3 March 10th, 2007 12:45
Updated jeep parts for sale Lots of after market and stock stuff 96xjeeper For Sale: Private Party Only. XJ ITEMS ONLY 13 February 23rd, 2007 19:46
wanted: Jeep or Sony tape player for my 96 flatlandernomore Colorado Chapter 1 July 28th, 2004 13:29
tape deck backinblack Wanted: Private Party Only 3 February 12th, 2004 20:24
Stock XJ parts (pics) Dazz For Sale: Private Party Only. XJ ITEMS ONLY 5 August 7th, 2003 20:13
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
