Custom XJ finished (almost)
Upgrades / Modifications
* The Donor Jeep only had 64,000 Original Miles on it.
* The exterior has been painted bright white The accessories are all white powder coat, not paint.
* New Black Outlaw Katzkin Seats
* Custom rear headrests
* New massbacked Black carpet
* New factory headliner
* New TruckLite LED Headlamps
* New Rigid LED fog lights in the front bumper
* New JCR Vanguard Front winch Bumper
* New XRB Vanguard Rear tire carrier bumper.
* New WARN Zion 8k Winch
* New JCR Crusader Rock Sliders
* New JCR Intergraded Rear Lower Quarter Panel Armor
* New Notch Custom Fender Flares
* New JCR Prerunner Roof Rack
* New KC Gravity LED fog Lights
* The entire motor has been gone through, Top to bottom. The donor motor only had 60k on it before the tear down
* New Gaskets
* New Plugs
* New Wires
* New Cap
* New rotor
* New 17-inch Mickey Thompson Deegan 38 Pro 4 Aluminum Wheels
* New 35-inch Deegan 38 tires
* New Lug Nuts – 50 Cal
* New Bullet air caps – 44 MAG
* New Brake Lines
* New Iron Rock Offroad Frame Stiffeners
* Everything under this XJ is also brand new, or has been stripped down and made to be brand new again, such as the non-wear items like calipers and drive shafts
* New Wheel Bearings
* Wheel Hubs
* New U-Joints
* New Drums and Hardware
* New Fluids
* New Rotors
* New Brakes
* Rebuilt Dana 30 front
* Rebuilt Chry 8.25 Rear
* New 6.5-inch Iron Rock Offroad Critical Path Long Arm Suspension Kit.
* The Entire Frame has been cleaned to look like it was never out of the factory, then it is lined with Linex
* New IRO Slip Yoke Eliminator
* New 2.5 inch Performance Cat Back Exhaust System
* New IRO Heavy Duty Over the Knuckle Steering kit
* All of the bolts and nuts in the lift and components are brand new. If it could be replaced with stainless steel it was on entire vehicle.
* New Sony Media deck
* New speakers, JBL , Infinity and tweeters and under seat subwoofer
* New exterior light lenses and all LED bulbs
* New LED interior lighting
* New rear backup camera
* New Rear Hatch Pumps
* New Yellow Top Optima Battery
* Tinted windows
* All interior removed and 2nd Skin installed in entire interior and inside doors
* New Custom Door seals (because we know XJs love to leak)
* New under hood cover
* New door checks, pins, brackets
* New entry scuff plates
* New door Ghost Shadow lights
* New rear mount fire extinguisher
* New rear mount XJ storage bag
* New LED license plate mount
* New rock guard clear surface protection
* New manual window handles
* New rear floor courtesy lights added (LED)
* New smartphone charger in center console
* Entire interior treated with 4 step Rust Bullet process
* New Gatorback serpentine belt
* New Factor55 Hitchlink (rear)
* New Factor55 Prolink loaded shackle mount (front winch)
* New Stainless Steel receiver lock
* All new stainless steel shackles
* D-Ring isolators
* New door ajar switches
More to come as I think of them…
Thought of a few more items:
* New custom fit AMP Research Powersteps
* New MEAN GREEN BATTERY HOLD DOWN
* New hood hinges and latch
* New driver and pass aluminum door latch reinforcement plates
* New rear sill cover
* New door latch spacers
* Door hinge shims and bolts
* New Magnetic oil drain plug
* New center high mount brake lens (try to find a new one)
* New gear shift handle
* Rebuilt power steering gear box and drop pitman arm for lift
* Steel knee bolster impact plate (under steering wheel)
In the top thread I referenced the addition of a
It looked really cool and was powder coated however it rusted internally almost immediately. There were too many tube openings leaking rust so I removed it. I went with the retro 90s look of the Carr light bar instead.
WOW - your attention to detail is amazeballs. I LOVE your XJ.
Where did you get that bag in the back that is in the hole on the pass side?
Very well done! :cheers:
Very nice and a lot of work.
I have wondered what my XJ would look like in white, it may happen yet.
Guess you intend on owning it for while, do keep the salt off it. XJs hate the stuff.
What are your plans for the axles and brakes? 35"s stress the stock brakes big time.
A word of caution on the bag install, the velcro does not adhere. I found a product that I have used throughout my XJ renovation called Sugru. It is moldable rubber and is amazing stuff. I created a waterproof plug for my light bar along with being able to plug almost anything with it. I used it to install the bag as well.
No plans at the moment to alter the axles or the brakes. It doesn't get many miles put on it.
Thanks for the compliment here. As you know there is always something else you can do to an XJ.
