streetxj
- Pembroke Pines, FL
I've been having bad luck with autozone duralast tps sensors. When I had the old original one, I noticed that my torque wouldn't lock-up in overdrive after driving a few blocks, especially when the engine reaches near max temp. When I replaced it with a duralast tps sensor, the problem was fixed and the torque converter would lock-up in overdrive constantly like it's suppose to. Now, it doing the same thing after three weeks and I replaced it with another new duralast TPS sensor. It actually runs smoother, but now the torque converter wouldn't lock-up at all in overdrive. So I'm going to have to return this one and get another one. If the same thing happens again, I'll ask for a refund. In that case what other TPS sensor can I buy that is actually a good durable brand? I know about OEM Mopar, but that's expensive. I've heard a few horror stories with Standard Motor Products and BWD. Basically, my decisions are Napa Echlin, Delphi and Crown TPS sensor.
I'll appreciate any advice.
