96 XJ, Rubicon Express 5.5" lift with long arms so it has the belly pan skid plate, etc.
I am parting the thing out and sold the transfer case. I have all six bolts unbolted but it's stuck on the transmission.
To get the top bolts out, I took a sawzall and cut a large hole in the transmission tunnel, worked great, they came off easily from above.
I can pound in a screw driver from the interior in between the trans and t case but the studs are keeping it from coming off all the way, and I can't pry it off from below because of the belly pan skid plate.
I tried jacking it up and down, etc... not working. I also do not have motor mounts installed so the engine and trans kind of wiggle up and down...
ETA wait... is there a bolt directly under the transmission mount??
