Old February 12th, 2018, 11:39
ehall's Avatar
ehall ehall is offline
Re: Electric air pump info needed
I have the MV-90, pleased with it. Fills all my 35s reasonably fast. High duty cycle.
my '91 beater rebuild
Old February 14th, 2018, 08:14
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
The one thing that I personally would look for is a 100% duty cycle. Yes, I know that narrows the field quite a bit.
I have both a Quick Air 2 compressor and CO2. The biggest problem I have with the compressor is elevation above sea level. CFM ratings are great and all that if there is available air to compress.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Old February 14th, 2018, 12:09
burntkat burntkat is offline
NAXJA Member #1145
Great points there, Bent. Luckily I don't have to deal with them at present, as I live in the SC Lowcountry. But if that changes, certainly I want a higher quality compressor with more usable runtime.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Any info on keeping my Electric Fan on for 15 min after shutdown? Redsnake Modified Tech Discussion 10 May 4th, 2012 09:09
12v electric WINCH INFO only in a Jeep Midwest Chapter 16 July 15th, 2011 12:08
97 XJ fuse diagrams and info about electric fan indianajeeper OEM Tech Discussion 7 April 13th, 2011 15:36
Electric water pump? jdxj Modified Tech Discussion 11 July 27th, 2009 22:31
Electric Water Pump? Root Moose Jeep Street and Performance 7 September 4th, 2008 17:13
