Old February 14th, 2018, 05:21
DutchVDub's Avatar
DutchVDub DutchVDub is offline
Re: Projext "V8 XJ" Build
Sounds perfect then. Swap in a V8 for the extra power and then don’t dare use that power for fear of breaking the Jeep. He is also running 37’s. That’s a lot of tire for a Dana 30, especially with a LS. Don’t get me wrong, I like my Dana 30. This is my second XJ with a locked and geared Dana 30 on 35’s and I’m plenty confident in it. I still wouldn’t swap an LS into my XJ w/o planning for some stronger axles, especially with 37’s. I’d hate to get a little too excited about the Orange Julius at the mall and destroy my axle goosing it over a speed bump.
But hey, if the OP wants to go back to stockish axles. I’ll gladly trade you those built 9” ones for my Dana 30/8.25 combo.
Americans can sleep at night because US Soldiers stand ready to fight
Old February 14th, 2018, 09:09
clydefrog's Avatar
clydefrog clydefrog is offline
Yeah, 37's and locked may be a bit much.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old February 15th, 2018, 11:50
PhotoJared's Avatar
PhotoJared PhotoJared is offline
I could swap in the D30 but the F9" lug pattern is 5x5.5.
I could also try swapping the oil pan for something smaller and using a oil filter relocation.
Old February 19th, 2018, 13:22
PhotoJared's Avatar
Speedway motors has a low profile pan that requires you to use an oil filter relocation. I might try that
Old February 19th, 2018, 13:28
PhotoJared's Avatar
I also could hear a really bad exhaust leak. I figured it was a cracked header and I just hadn't had time to actually get under and find it. Slid under last night to find it and bam! Already ordered an ATP header from Amazon.
Old February 20th, 2018, 09:43
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
Are ATP headers the headers to get now? Seems to be a lot of back and forth on which headers to get.
Old February 20th, 2018, 20:09
PhotoJared's Avatar
I was going to order APN but they’d take too long to receive. My wife and kid will be out of town for the remainder of the week so I’ll have a chance to install it.
PhotoJared's Avatar
I figured I might as well try it out.
Old February 21st, 2018, 17:38
cleenrob's Avatar
cleenrob cleenrob is offline
the apn header is garbage
Old Yesterday, 13:01
PhotoJared's Avatar
I didnt feel like spending $350 in a Banks Torque Tube when I dont even know what I'm doing with the engine.
So the #6 header pipe was completely detached from the collector. Jeep sounds much better now.
Old Yesterday, 13:26
R6TeXJ's Avatar
So you already have the APN header installed?
Old Yesterday, 13:35
PhotoJared's Avatar
*ATP, but yes its already installed. Only took a couple of hours.
Old Yesterday, 13:48
R6TeXJ's Avatar
I guess everything went in ok? Where did you buy it from, link?
Old Yesterday, 14:22
PhotoJared's Avatar
Install was fine no easier or harder than any other install i've done (this is my 3rd or 4th). I had to grind down the underside of the #6 intake runner and bash in the #6 header pipe a little bit but it went as smoothly as any other install i've done. The header design also doesnt allow you to get any of the bolts so I just tighten them down enough. That's probably where the Banks would outweigh this header (design).
Other than that a header replacement shouldnt take longer than 3 hours if your bolts arent rusted. Everyone always makes it sound harder than it really is.
https://www.amazon.com/gp/product/B0...ag=pd a0ea-20
Old Yesterday, 14:44
R6TeXJ's Avatar
thanks man!
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 275 February 5th, 2018 15:59
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 23:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 04:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 03:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 13:19
