Old December 1st, 2017, 20:07
SByota SByota is offline
Re: New guy build-The Family Truckster
Got one side all done. Other side is about 3/4 done.
Old December 26th, 2017, 20:04
It's coming together slowly. Got the SYE installed and t-case back installed. Fresh paint on the trans cross member and my fabricated transmission mount.
Started on the driver side motor mount. I love having my mini fixture table. Makes measuring stuff like this so easy.
Picked up a new toy. $200 for a very basic 3-1 mill/drill/lathe machine. It was never used and was still covered in grease from 1994. It is so nice to be able to face off tubing to make it square. I wish I would have paid attention better in High School shop class. I'm learning as I go.
Old December 27th, 2017, 07:57
burntkat burntkat is online now
NAXJA Member #1145
Got any info on the mini fixture table?
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old December 27th, 2017, 16:34
I made it from 3/8” cold rolled steel. The top slats are 3” wide with 5/8” holes every 2”. There are 2 2” runners on the underside tying it all together. The space between the top slats allowes a c-clamp to fit in.
I really wanted a tab and slot style table, but they are expensive and I’m cheap. I also have a really solid workbench with a stainless top. The small size let’s me move it out of the way when needed. I absolutely love it, being able to fixture parts is amazing. I should have built it a long time ago.
Old December 28th, 2017, 07:48
NAXJA Member #1145
I'd love to see pics if at all possible. Perhaps a different thread?
Apologies if you've already posted pics- I can't see them, or indication of them, at work.
I was looking at this:
https://weldtables.com/collections/p...ar-pro-top-kit It's a 2X3 kit that ships flat, then you knock it together and weld into a reinforced structure.
Old December 29th, 2017, 19:52
Worked on the driver side motor mount plate today. The stock ones are only held on by 3 bolts and are prone to failure. I am also going to raise the motor up 1/2" to help with track bar clearance at full bump. Also had a little garage elf with me.
Old January 8th, 2018, 11:52
Driver side motor mount done and installed. I made a really stupid mistake and somehow lost an inch when I located the through bolt holes on the motor plate side. Should have measured 4 times I guess. I was able to fix it, but it didn't come out as clean. At least its done.
Old January 13th, 2018, 22:21
Every once and a while I get one just right. Passenger side motor mount almost done.
Old January 23rd, 2018, 18:01
Motor mounts all done and installed. Of course the second one was WAY faster than the first one. Started on the double shear for the pitman arm. It's all tacked up ready to be burned in. Ran out of time today and had to get ready for work.
Old January 31st, 2018, 12:42
Exhaust is all done and. The OEM system was rusted out and done. It was also tiny!! as small as 1.5" in places. It's all 2.5" now with a cheapie Summit Racing "race bullet" muffler, which is basically small glasspack. This was my first time doing exhaust, I'm pretty stoked on how it came out. Front axle truss and gears are next, the I can do final assembly on the front.
on how it came out.
Old February 10th, 2018, 10:53
Got the new exhaust installed for real. Started painting stuff and getting the front end prepped for final assembly. It feels good to be getting somewhere.
Old February 10th, 2018, 17:41
DutchVDub's Avatar
DutchVDub DutchVDub is offline
I love the fab work on this, great job. I also like your mini fixture table. I take it with the slots you're able to use cheaper and easier to source C-clamps.
Do you have any more pictures of your upper shock mounts? I have the generic adapters on mine but really like how yours turned out.
Americans can sleep at night because US Soldiers stand ready to fight
Old February 22nd, 2018, 15:56
Yes, the space between the slats lets me use regular C-clamps. I also drilled 5/8” holes and modified some C-clamps into fixture style clamps. Lots of clamping options helps tremendously.
The upper shock mounts are T&J Performance pre-fabbed mounts with gussets added to the OEM unibody. Let me see if I can find more detailed pictures.
Old February 23rd, 2018, 19:35
macgyver_7_6 macgyver_7_6 is offline
You've got some nice welding skills. Like your exhaust. I just did my exhaust last summer. 2.5 summit pipes and band clamps with magnaflow hiflow cat and borla muffler.
Have some things on the to-do list you have already done...frame stiffeners, motor mounts, & SYE.
Nice pitman arm! Also, looks like you've got a future jeeper in the works. I could use some help...send him my way when he gets a few years on him!! Hee hee!!!
Family centered overland build overxjland Adventure Forum 5 February 25th, 2016 11:41
Tom95YJ's Family Wheeler Build ... Tom95YJ Modified Tech Discussion 80 March 2nd, 2013 23:25
Family wheeler build XJdriver Arizona Chapter 23 December 24th, 2012 12:16
The Family Build CarolinaCrawler South East Chapter 18 October 22nd, 2012 10:19
