Erik
- With Betty
I have a couple of projects going which require some plumbing knowledge, and of course I'm completely ignorant. Maybe someone can set me straight on terms, resources and such. First item: I need to replace a front pass. brake line, and the 3/8 inverted flare fitting on the hardline is all fouled up (Vise-grip modified). Question is, is that a 37 or 45 deg fitting? It should be a 3/8 male fitting for a 3/16 hard line, and I'll be connecting it to a RE 4" brake extention and then to a stock YJ brake line. If you have a resource for the part and can set me straight on the terms, that would be most helpful. Second question, I have a leaky connector on my AT line to the cooler (return). So I need to transition from a 3/8 OD stock tubing to a 5/16 ID Stainless steel tubing. Any ideas? I just bought a flaring tool and would still need to order the tubing and connectors.
