MadMachinery
- Jupiter
My 98 xj has been having some issues. It will feel like it's not getting enough power and I will hear a knocking/kicking sound near the driver's side. If I mash the pedal sometimes it will get power, but it will start to buck if I don't keep her at 3000+ rpms. It will also buck and idle high or idle too low when stopped. Along with sometimes stalling at a stop. The problem gets worse the hotter it gets. I thought it may of been the TPS based on research, but I replaced it with a Mopar TPS and it's still having these issues. The only other thing I can think of is CPS, which I will try to test today. But I'm unsure of that because normally the CPS will just fail outright and not work. The only codes I get are p0700 and p0751, which has to do with solenoid a. I already ordered a master solenoid replacement kit and plan on doing it over the weekend. I could really use your guys help in troubleshooting my problems!
