97 XJ, I can feel occasional taps/knocks in the floor board under my feet at idle?
It's most likely in the exhaust system. Look at both the exhaust mounts and the trans/motor mounts.
Could be the exhaust contacting the trans cross member? The exhaust can sag with age, the trans mounts get old, as do the motor mounts.
A quick test is to try and stick your finger tip between the (old) exhaust and the rear of the trans cross brace. If you can't get a finger tip in there, it is likely to be a problem.
