idle is too fast ?
srb531
annapolis, md
start it idle jumps to 1800 rpm , after 10 seconds drops to 1500 and stays there ? 98, 4.0 , auto, 140 k miles, stock motor, any ideas ? thx
Sticky IAC.
If the idle changes, it most likely is not a sticky IAC, but the inability of the IAC to adjust enough to compensate for a vacuum leak. Check for vacuum leaks. Clean the IAC/throttle body.
Clean the throttle body and Idle Air Controller. If the high idle is consistent day to day, look for a vacuum leak. If the high idle comes and goes on different days, or goes away after a re-start, consider buying a new IAC.
well, tps & iac are both replaced, t body has been removed & cleaned, sprayed everywhere w/ carb cleaner idle stays the same so cant find a vacuum leak . still idles at about 1800. anymore ideas anyone ? before i take it to a shop. thx btw what is the other device on drivers side of tb w/ wiring & plugged in ?
check the brake booster and the vacuum line that runs to the vacuum tank.
did thes just happen one day or did it slowly get worse?
got it fixed ,it was the iac. just had to disconnect batt. then comp. reset itself for the new part. thx all
