- Everett, WA
I have searched the forums and found a couple starting points but nothing that made me feel warm and fuzzy that I knew how to be sure what my issue must be. My '95 XJ has recently developed an intermittent issue with a generally short-lived rough idle, occasional slight misfire (slight enough I'm often not sure if I just hit a bump in the road), generally (but not always) accompanied by a CEL code 27.
Earlier this year I was chasing what ended up being a bad CPS that led me to replace injectors, fuel pump, TPS, CPS, IAC, O2, cap, rotor, plugs, wires, coil. So I am at a loss for what the issue could be now unless there is a short in the wiring harness or a bad ECU. It seems to have started when the first snap of cold weather came in.
Hoping someone here may have some insight on what else I could check, or be able to shed some light on how I can easily test the harness/ecu/injectors/etc. Still getting the hang of diagnosis on EFI.
