    More Information - Join/Renew
Vacuum line/hose
SkatingPenguin
Iowa
'97 Cherokee Sport 4L automatic...
Vacuum leak where the line passes under the battery (seems the common spot). Also, near firewall under the hood, I have a busted vacuum line from the T connection thru the firewall. Can anyone tell me the proper size diameter I need for both? Especially the one that goes through the firewall since I'll be changing my heater core, etc...
Also, did you use rubber/plastic/silicon replacements?
Thanks
They look like 3/16 and 3/8. Cut off a couple pieces and take them with you to a NAPA store. They should have lots of cheap (inexpensive), bulk vac line. AutoZone, O'Reilly's probably won't carry bulk line. Pick up some extra elbow and adapter fittings just for contingencies.
