Old August 14th, 2006, 10:04
Redsnake Redsnake is offline
Motor Mount torque spec?
I couldn't find my tech manuel this past weekend when I installed new motor mounts on my '96 XJ. I torqued the mounts to about 35 ft/lbs but wanted to make sure they're torqued to spec.
If anyone can post those I'd appreciate the details. Thanks.
Old August 14th, 2006, 11:10
lilredwagn lilredwagn is offline
Re: Motor Mount torque spec?
engine bracket bolts: 45
mount bracket bolts: 40
mount bracket nuts: 30
mount bolts & nuts: 30
mount through bolt nut: 48
Torque spec? riverfever OEM Tech Discussion 4 June 13th, 2006 21:19
Motor mount torque? Osprey413 Modified Tech Discussion 3 January 22nd, 2006 14:51
torque spec rngrfrd2000 OEM Tech Discussion 0 May 17th, 2005 09:43
need torque spec for 2.5 Dobbs OEM Tech Discussion 4 March 29th, 2004 22:14
8.8 Torque spec DesertXJ Modified Tech Discussion 5 June 20th, 2003 16:24
