Old March 3rd, 2015, 21:27
99lbxj's Avatar
99lbxj 99lbxj is offline
xj died out
I was at a stop when my 99 jeep xj died on me. I tried to start it back up and no luck. It cranks and it kicks on for.like 3 seconds and dies on me I pushed the gas valve by the injectors and I get no spray. Only a little bit of gas drips out if I'm lucky. I jumped the fuel pump relay and the I can hear the fuel pump kick on. Any suggestions?
Thanks in advance.
Old March 4th, 2015, 06:32
joejeep92 joejeep92 is offline
Re: xj died out
Alright, first off that "gas valve" is a fuel pressure test port for screwing on a pressure tester. However, you may still have a fuel pressure problem. Even if the pump is running with the relay jumped the pump may be worn out to the point of not producing enough pressure or volume. Rent, borrow, buy or steal a pressure gauge to tell you how much that pump is producing if you suspect fuel pressure. Don't get tunnel vision to that though.
Almost died just now... 89xjJe3per SoCal Chapter 20 December 3rd, 2009 22:30
XJ died on me RichP OEM Tech Discussion 7 July 19th, 2009 09:33
Starter Solenoid died...replaced....died... RickyN29 OEM Tech Discussion 9 January 3rd, 2007 19:02
died ABS on a 91 xj - please help Micha OEM Tech Discussion 12 December 31st, 2006 05:43
My XJ died..... Sarge Non-Tech / Off Topic 5 April 17th, 2005 20:53
