96 factory fog light wiring
gba88
PA
I searched, but couldn't find this specific.... I have a 96 that has the module that plugs onto the back of the factory fog light switch. I bought a switch from ebay, and was hoping that I could break into a harness under the hood somewhere to run some lights.
Can soemone tell me if this is possible, and if so where I can get at the appropriate wires under the hood? Thanks!
Check under the front bumper or behind the grill. You may already have the wiring there. JIM.
Unfortunately that was the first thing I did.......Nothing to be found there :( Thanks for the suggestion though!
In that case I would get a good FL kit. One that comes with all the wiring & the relay & wire it to the factory switch. Or buy the relay & build your own harness. JIM.
