Old March 5th, 2009, 20:14
latenights latenights is offline
exhaust leak on exhaust manifold
Just a quick question after trying to search for it. theres a pretty big crack in the exhaust manifold where it all collects at the end which is pretty common from what i've heard. thats not my problem, i already have new ones waiting to go in when the weather gets warmer. But i am gettin 11-12 MPG city on a stock height 96 XJ 4.0 with 30" BFG A/T. Im just wondering if that could be causing an o2 sensor to be off and making my gas mileage suck. I'm not concerned about this, im just wondering.
Old March 5th, 2009, 20:16
tbburg's Avatar
tbburg tbburg is offline
Re: exhaust leak on exhaust manifold
Yep. That can cause it!
Old March 5th, 2009, 20:21
Ok, thanks. I figured that's what it was but since most people on here are a lot smarted then I am I'd figure I'd ask. I got some new stainless ones with the expansion chambers for $100 at a swap meet so hopefully they'll be going in this weekend.
Old March 5th, 2009, 22:18
hubs97xj's Avatar
hubs97xj hubs97xj is offline
Check your motor mounts and the transmission mount- that is supposed to be one of the contributing factors to cracked manifolds- even my APN header has a little warning on the install sheet that worn mounts likely caused the stock piece to fail, and would wreck the header as well.
Old March 5th, 2009, 22:49
winterbeater's Avatar
winterbeater winterbeater is offline
Consider adding a stainless flexible joint into the system. Summit sells em. I don't see how those built in expansion pieces will help with the cracking thing.
Old March 6th, 2009, 05:46
ok ill check the mounts. i wasn't sure how they were supposed to help either since there not even on the same tube as where it cracks but i just got it anyway
Old March 6th, 2009, 08:58
hubs97xj's Avatar
Engine/tranny move around too much on worn mounts, the collector starts cracking as it can't move with the engine, exhaust escapes before the O2 sensor through the cracks, sensor sees a lean mixture, tells the PCM to dump more fuel in, tanking your mileage. That seems to be the prevailing theory- one thing leads to another. Not sure on the bellows, but if you can fix the root cause, it should be fine, even if they don't necessarily help.
Exhaust manifold leak and still misfiring ARBOGASTER OEM Tech Discussion 0 September 17th, 2008 12:30
exhaust manifold gasket leak? ehall OEM Tech Discussion 7 June 19th, 2008 23:44
exhaust manifold leak mitsumotors OEM Tech Discussion 5 March 3rd, 2008 14:25
Dorman Exhaust Manifold Leak boise49ers OEM Tech Discussion 3 October 23rd, 2007 11:57
heat/leak exhaust/new exhaust. TheManch Modified Tech Discussion 5 May 27th, 2004 18:28
