robertxj
- Rochester, NY
Attempted to change out a front left brake line on the wife's 99 XJ last night. Of course the line I got from parts store had fitting that didn't work. I had one good fitting from bad line that I was going to use on proportioning valve side. It leaked worse than the perforation in the line. Can anybody tell me (1) if the adapter fitting in the proportioning valve (Master cylinder end) is available, because mine is now damaged, and (2) whether it is an inverted (double) flare, or bubble flare at the prop. valve? I know its probably covered somewhere, but I've searched and can't find it. Thanks
