The Luke
- Cookeville, TN
So, I loaded my 96 Xj country on the trailer, strapped it down and decided to throw on some rock lights at the last minute. At some point, I forgot that I had the switch on while routing wires and it sparked against my cage.
Which now brings me to my problem. When you turn the key to run, the ac clutch engages(even with the ac off) and the aux fan turns on. The radio and everything other than headlights is dead. Fuel pump won't cycle.
It will turn over but will not fire because of the fuel pump not engaging. Computer will not scan.
Due to all that, I assumed ecm. I replaced it and nothing changed. So now I have an extra. I've also checked every fuse with a meter and they are all good. I've changed fuel pump relays, no luck.
Any help here? Things to try? Any and all help is appreciated.
