Old October 11th, 2008, 21:14
stephenspann27 stephenspann27 is offline
Has my engine been Rebuilt?
I'm in the process of dropping my oil plan to replace the rear main seal and the rod bearings, and I noticed the rods and caps are numbered. I know ppl usually do this when they rebuild an engine. Does anyone know if they come like this from the factory?
Old October 12th, 2008, 04:49
Kevinma255 Kevinma255 is offline
Re: Has my engine been Rebuilt?
not likely factory but could be. I had two 4.0s apart and there were no numbers. with a 4.0 the general rule of a rebuild seems to be if it aint broke dont fix it so if you are doing a rebuild as preventitive I would just leave it alone, it will start making bad noises when it needs something.
Old October 12th, 2008, 07:49
Rick Anderson Rick Anderson is offline
My '69 440 cu. in. that I rebuilt had the connecting rods numbered, it was its 1st Re-Build.
It may be something that changed from year to year at the factory.
Old October 12th, 2008, 21:48
RichP's Avatar
RichP RichP is offline
See if the head bolts have paint on them, general rule is to mark headbolts the first rebuild or the first time you pull the head so they don't get reused more than once.
Old October 16th, 2008, 11:58
VAwheeler's Avatar
VAwheeler VAwheeler is offline
My rod end caps from both of the 4.0's that I took apart had them numbered. Neither of them had been apart before. The numbers were stamped on the flat portion of the end cap.
Anyone here rebuilt an engine BIgDaddyChia Red River Chapter 8 March 1st, 2008 05:11
rebuilt engine outlander OEM Tech Discussion 7 November 10th, 2005 11:37
anyone rebuilt engine on 8N Fords? Gridikal Non-Tech / Off Topic 2 November 30th, 2004 09:38
Rebuilt Engine!! cbert1234 OEM Tech Discussion 5 February 15th, 2004 12:04
Is my engine rebuilt tnfan77 OEM Tech Discussion 6 August 27th, 2003 08:39
