Old November 6th, 2005, 19:44
outlander's Avatar
outlander outlander is offline
rebuilt engine
I am very close to hitting the buy it now button on this engine but first wanted to ask if anyone has anything bad to say about this company.Are these motors junk with knurled valve guides?Are they worth the money?
Should I look elsewhere?
http://www.rebuilt-auto-engines.com/...35103232906.cc
Old November 6th, 2005, 20:05
langer1's Avatar
langer1 langer1 is offline
Re: rebuilt engine
Did you read this page?
What are the engine specifications?
Engines remanufactured by our remanufacturing line meet or exceed O.E.M. specifications.
- New Manley valves
- New Elgin valve springs and keepers
- New Badger pistons
- New Hastings molly rings
- New Dynagear timing gears and Durabond cam bearings
- New Dynagear timing gears and chain
- New Elgin lifters, push rods, rockers, balls and nuts
- New Dynagear oil pump
- New FelPro gaskets
- Cylinder heads are pressure checked
- Diamond honed valve guides
- Three angle cut valve seats
- All head surfaces are broached
- Blocks are bored with deck plates, cylinder walls are diamond honed
- Crankshafts are ground and polished for .002 clearance
- Camshafts are ground to O.E.M. specifications, hardened and polished
- Connecting rods are sized to .002 clearance
Old November 6th, 2005, 20:06
old_man's Avatar
old_man old_man is offline
Re: rebuilt engine
I have never seen a rebuilt crate motor that did not have knurled guides. Personally, if you can stand the wait, I would have a local machine shop rebuild it for you. Around here you can get it done just as cheap or cheaper. It just means waiting about a week, but you know what you are getting. Also most machine shops warranty their work, not that the crate isn't, but if you have a problem, it is nice to have the people you are dealing with, be local
It is so nice to see someone thinking about the valve guide knurling. It just about guarantees that the engine will be burning a lot of oil in 10K-15K miles. They just bet you either lose the paperwork or sell the vehicle.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old November 8th, 2005, 01:30
outlander's Avatar
Re: rebuilt engine
Yea I want to avoid knurled guides at all cost!
I talked to my local napa machine shop today and they gave me a price of about $800.00 just for the machine work on the block and head and assembly of the head.That seems steep?The rebuild kit(dana)was like $650.00 more.....so I would have about 1500.00 in a motor that I would still have to assemble my self.
Are they trying to bend me over on this???
Old November 9th, 2005, 19:33
mattmankow mattmankow is offline
Re: rebuilt engine
I put a Jasper in my Y2K XJ. 3/75 warr. parts and labor. You put the first one in and if it fails take the Jeep to a Jasper dealer and they will pay them to put in the next. Pretty good deal at $1750.
Old November 9th, 2005, 22:22
sflier sflier is offline
Re: rebuilt engine
for those of you like me who hadn't heard or knurled valve guides:
From the Web -
The engines covered in this guide use integral valve guides. That is, they are a part of the cylinder head and cannot be replaced. The guides can, however, be reamed oversize if they are found to be worn past an acceptable limit. Occasionally, a valve guide bore will be oversize as manufactured. These are marked on the inboard side of the cylinder heads on the machined surface just above the intake manifold.
If the guides must be reamed (this service is available at most machine shops), then valves with oversize stems must be fitted. Valves are usually available in 0.001 in. (0.025mm), 0.003 in. (0.076mm), and 0.005 in. (0.12mm) stem oversizes. Valve guides which are not excessively worn or distorted may, in some cases, be knurled rather than reamed. Knurling is a process in which the metal on the valve guide bore is displaced and raised, thereby reducing clearance. Knurling also provides excellent oil control. The option of knurling rather than reaming valve guides should be discussed with a reputable machinist or engine specialist.
Old November 10th, 2005, 02:58
outlander's Avatar
Re: rebuilt engine
What site is that info from?
Old November 10th, 2005, 11:37
Re: rebuilt engine
I read it from this site: http://aarc.epnet.com/application/90...lve_Guides.htm
There is more info also from this site: http://www.hastingsmfg.com/Service%2...e_knurling.htm
Rebuilt Distributor XJTripp OEM Tech Discussion 15 January 21st, 2005 05:04
Engine seems to want to cut out. Osprey413 OEM Tech Discussion 3 August 10th, 2004 08:16
Help!! Engine Is Blown! jddancy OEM Tech Discussion 19 July 9th, 2004 14:55
Engine computer - can someone help me please? jma OEM Tech Discussion 11 November 20th, 2003 11:58
where to find a ceap rebuilt engine Stoney Sierra Chapter 6 August 6th, 2002 19:02
