Old March 10th, 2012, 16:29
sheffeyva's Avatar
sheffeyva sheffeyva is offline
Question on HVAC controls!
While blindly removing all unnecessary wires and hoses I might have gotten rid of my HVAC vacuum controls!
Is this the two vacuum lines that need to be connected? I only have heat blowing out my defrost by the windshield and I'm assuming these are them. Just wanted to make sure.
Old March 10th, 2012, 16:42
Shorty's Avatar
Shorty Shorty is offline
Re: Question on HVAC controls!
sure looks like 'em to me!
P.S. small block chevrolet in that one?
joe_peters :Listen to Shorty--he has spoken wisely
Ecomike :Listen to Shorty--he has spoken wisely
X2
Old March 10th, 2012, 16:50
sheffeyva's Avatar
Certainly is a "small" block! Just a 2.8l V6 ! I put on an edelbrock manifold and holley carb and literally ripped off everything else! Luckily this all works on the 3.4l if I go that route but maybe a SBC in the future. It only has 80k on the motor so I figured I'll run it till it dies then upgrade. I more using this Jeep as a learning project for the suspension since I am coming from the world of Sport Compact cars!
Old March 10th, 2012, 16:52
Shorty's Avatar
I saw that after I posted-- only 3 plug wires coming off the cap!! You beat me to the response before I could edit my question
X2
Old March 10th, 2012, 17:11
sheffeyva's Avatar
Old March 10th, 2012, 17:15
sheffeyva's Avatar
Another question is how would I go about connecting these plastic lines to a single vacuum source? For the life of me I can't find fittings to change these for hard to soft lines so I can run them to the intake manifold.
Old March 10th, 2012, 17:19
Shorty's Avatar
the first XJ I ever played with had the same set up! I got it running for someone else and thought I'd seen the last of Cherokees for ever......
A couple years later I had one fall into my lap for a song and the guy I helped with the '86 gave me the lift off it as a "thank you" for helping him get it running (two years after helping)
I'm still running the lift today-- shoulda kept the '86 for spare parts, but still woulda scrapped the 2.8L
X2
Old March 10th, 2012, 17:23
Shorty's Avatar
find some soft line that'll fit snugly over the hard line and a "Y" fitting for the vacuum hose. Run each hose to the "Y" and then into a constant vacuum source. The factory vacuum source was run into a vacuum storage canister (softball like reservoir behind the front bumper) to aid in HVAC operation during times of low engine vacuum.
X2
Old March 10th, 2012, 17:25
sheffeyva's Avatar
Definitely not rebuilding this sucker when it dies but it has good compression and gets around just fine here in the hills of Portland on 32's and stock 4.10 gears. Probably going to start building a SBC of some kind here soon that way i can just swap when it does die!
Old March 10th, 2012, 17:27
sheffeyva's Avatar
Would it be fine running to full manifold vacuum or should I fab up a vacuum ball like the factory. I'm getting about 22hg of vacuum at idle.
Old March 10th, 2012, 17:32
Shorty's Avatar
you'd be fine at idle and under cruise conditions (low throttle), but as you've learned, the default position of the air door is defrost. Any time you're "on the throttle" or climbing a hill, you'll lose enough vacuum for it to default to the windshield.
I'd find a small vacuum ball at the boneyard and put it in line.
X2
Old March 10th, 2012, 17:37
sheffeyva's Avatar
Thanks for all your help! And by the way I used to live in the same area you do. I lived right off of Princess Anne blvd in Virginia Beach. Really miss that area. I graduated high school over in Newport News awhile back also. I've been back there twice to live so far. I love the 7 cities area!
Old March 10th, 2012, 17:41
Shorty's Avatar
Thanks for all your help!no problems at all-- glad I could help. I love the 7 cities area!I think you need a check-up from the neck up
X2
Old March 10th, 2012, 17:47
sheffeyva's Avatar
LOL! To each their own! I hate the Pacific Northwest but some people think this is the greatest place ever !
Old March 10th, 2012, 19:23
djgrayxj djgrayxj is offline
Note from DJ
Take a look at this possibility for the location
1998 a/c vacuum canister
http://www.naxja.org/forum/showthread.php?t=1039575
Link to Picture by carves in post # 13 or hear it is
http://www.jeepforum.com/gallery/sho...limi t=recent
The square vacuum reservoir off a TJ is easy to fit in a cramped engine bay.
I just have mine on the front cross member.
The vacuum reservoir is the Black object to the left of the yellow arrow.
Only defrost setting works on hvac controls? Raymont OEM Tech Discussion 4 February 25th, 2010 23:09
HVAC Controls originalxj OEM Tech Discussion 5 October 19th, 2008 20:58
HVAC controls - clarification? mattbred OEM Tech Discussion 3 February 3rd, 2008 02:52
Light Bulbs for HVAC controls BAs96XJ OEM Tech Discussion 5 August 11th, 2005 15:36
HVAC controls imma honky Modified Tech Discussion 1 February 8th, 2005 14:55
