lilredwagn
- South Carolina
So about 3 years ago I decided I wanted red cockpit lights and replaced the 194 bulbs in the instrument cluster with red ricer bulbs. It looked pretty cool for a while, and then, just like everyone said they would, the bulbs burnt off the coloring and the light faded to an ugly pale orange.
I had used theatre gel in various places around the dash (stock radio, key illum., shifter panels), and I tried cutting some to fit the cluster, but the way the lights shine up through the gauges, it's extremely difficult, and any place that lets white light through will fade out the color. So I gave up and drove it like it was for a couple years.
In the recent process of totally gutting the interior, the dash came out, and I took the opportunity to do this right.
There are two other options that I am aware of.
One is using EL glow string beind the front bezel. I don't like this option because you lose the dimmer, your colors are limited, and supposedly EL string loses intensity over time. Plus it's (imo) a wiring hassle.
The second option would be to go to glow-gauges. I personally do not like white face (green blue, whatever) gauges, so I would want reverse glow gauges. Aside from the color limitations (I want red), there's the rather difficult problem of viewing unilluminated gauge needles at night with the reverse setup. I could probably make something myself if I could successfully remove and replace the needles, but on a 96, apparently removing the needles destroys the gauge.
Anyway, that's why I decided on this method. On with the show.
After a fair bit of measurement and test fitting, I created a CAD file and sent it off to Phil at bclaserworks.com to be cut in 1/8" transparent red acrylic. He was very helpful and offered a great price too. After receiving the finished piece, I made some final tweaks and put a copy here for your use: http://www.savefile.com/files/2213149 You may use the file and design for personal use. If I catch you selling these templates I will find you, rip off your larcenous arms and beat you to death with them.
Here's what I got back:
Ooooh! Pretty red:
Just a hair too small though. I modified the file to correct this:
Letting it rest on the existing ledge leaves a gap, and that won't work:
So I cut a couple pieces of acrylic to act as supports. I left room on top to glue some foam on so that there's no rattling:
Actually I got so frustrated with one of the little stands that I snapped it out and just glued (JB Weld) the foam to the side. I added another little strip to the piece on the bottom half to bring it up to the desired mark:
Finally, I ran a very thin bead of silicone along the top edge of the cutouts, so that the back of the gauges doesn't rattle against the acrylic. I also ran a thin bead around the outer edges so that it fits tighter into the cluster, but that shouldn't be necessary with the modified file:
If you want red turn signals, you will have to sand the green color off the little plastic insert and sandwich some colored theater gel in between. There is not a lot of clearance, so a piece of acrylic will not fit there.
Do note that the gas gauge MUST be inserted while the panel is outside the cluster, as it will need to be angled in. The rest of the gauges can be placed in after the panel is installed.
With all those pictures you'd probably expect one at the end of the finished result and how it looks at night. My dashboard is still not back in the jeep, but I felt like getting this out of the way. I will post finished pics in a week or two and that will be a good excuse for me to bump my own thread
Ooooh! Pretty red:
