RWKHausSupply
- yorba linda, Cali
This is brand new direct and free shipping!
1275$ AND FREE SHIPPING.
Over 20% off others selling the same exact winch!
http://www.quadratec.com/products/92101_100_07.htm
http://www.amazon.com/WARN-71800-PowerPlant-Compressor-Winch/dp/B000OQ3Y4Y
http://www.summitracing.com/parts/wrn-71800
THIS WILL RUN AIR TOOLS! AND PULL YOU OR ANY BUDDY OUT OF WHERE EVER THEY ARE...
Warn PowerPlant Dual Force HP winches are multi-tools you don't want to leave civilization without! Perfect for hardcore off-roaders, these energy centers elevate your rig to a new level of off-road capabilities. They're powered by a robust 4.6 hp Gen II series-wound motor to help you zip off lug nuts or air up four tires in minutes like a NASCAR pit crew, or pull yourself or a buddy out of any worst-case scenario when you're stuck. You're just a flip of a switch away from compressor or winch modes. PowerPlant HP compressors flow at 5 cfm at 90 psi with a built-in air tank and intercooler and the winches pull an amazing 26.9 ft. per minute at no-load with a 9,500 lb. capacity. A good winch is a great investment to keep a good day from turning into a bad night, especially if you travel alone. Head into the wilderness with the right tools to survive. Go prepared--go with Warn PowerPlant Dual Force HP winches.
WARN breaks new ground in the off-road world with the PowerPlant Dual Force. It's one space-saving on-board unit. Both a top-end winch, and a high-end air compressor. Just flip the activator switch to compressor mode and discover the can-do attitude of the PowerPlant. Powered by a 4.6 hp motor, the PowerPlant puts out 5 cfm @ 90 psi, with a built-in air reservoir and intercooler. That translates to airing up four 35" tires from 8 psi to 35 psi in 8 minutes. Or less. And with the PowerPlant, there's no labor-intensive compressor set up: it's part of our standard winch mounting process. Switch to winch mode and the PowerPlant turns on the latest in legendary WARN winch technology. You get the raw pulling power of our Gen II Series Wound motor. Plus the proven reliability of the 3-stage planetary gear train and a newly designed contactor that's rugged and reliable. In other words, WARN to the rescue, time after time.
Limited Lifetime Warranty.
Best in class on-board air, plus a winch geared to deliver the fast line speeds serious off-roaders demand
12 CFM @ 0 psi, 5 CFM @ 90 psi air flow rating
100 psi max air pressure
9,500 lbs. maximum rated pull (single line)
Fast line speed of 26.9 feet minute (no load), 5.2 feet per minute (at 9,500 lbs. max load)
125 feet of 5/16" wire rope
Air flow rating: 12 CFM @ 0 psi, 5 CFM @ 90 psi
Max air pressure: 100 psi
Rated Pull: 9,000 lbs. single line
Motor: Series Wound 4.6 hp 12V
Remote Control: Hand-held remote control with thermometric indicator
Geartrain: 3-Stage planetary
Gear Ratio: 156:1
Clutch: Sliding ring gear
Brake: Automatic direct drive cone
Drum Diameter/Length: 2.5"/9.0"
Wire Rope: 125' of 5/16"
Fairlead: Roller
Finish: High gloss, powder coat finish over chromate coating
Weight: 100 lbs
12V DC Performance Data:
Load (lbs.) Current (amps) Speed (fpm)
9,500 475 5
9,000 454.5 5.2
8,000 419.9 6.1
6,000 344.9 7.8
4,000 261.8 10.3
2,000 194.6 14.6
0 87.7 26.9
Parts Included
Winch
125' of 5/16" Wire Rope
Nylon Air Hose
Hand-held Control with Thermometric LED
Quick Connect Couplers
Tire Gauge and Dual Air Chuck
Robert
RWK Haus Supply
714-875-2414
www.RWKHausSupply.com
Gear Ratio: 156:1
Fairlead: Roller
Weight: 100 lbs
9,500 475 5
9,000 454.5 5.2
8,000 419.9 6.1
6,000 344.9 7.8
4,000 261.8 10.3
2,000 194.6 14.6
0 87.7 26.9
Parts Included
Winch
Nylon Air Hose
Robert
RWK Haus Supply
714-875-2414
