how to disco the CPS sensor connector?
XJ98Jeep
Atlanta
Well, I got through what I THOUGHT was the hardest part of a Crankshaft position sensor replacement (Getting it off of the bellhousing) but I have no clue how to disconnect the connector that's attached to my intake manifold... Any help?
It's a 98 XJ with the 4.0.
Attached? My 88 had a small clip that held the harness. I was able to slide mine out.
The CPS plug has a little lock/clip that needs to be pressed as you pull it apart. It might help to get the plug loose from the mounting bracket so you can see it better.
