randyf
- Indianapolis
I need to go buy a line wrench to replace my wheel cylinder and rear brake assembly. Does anyone know what size line wrench I need to buy for the rear line going into the wheel cylinder?
You just might want to spray the connection with some penetrating oil.
Recently replaced all four lines, three no problem, fourth was a dirty blankety blank.
They can be stubborn at times.
3/8 line wrench get a good one the cheap one tend to flex some and can strip out the fitting.
That's what I used to do before I discovered really good flare nut wrenches. Now, if the nut has not already been damaged by vise grips, I use the correct wrench. The penetrating oil and the back and forth movement are the same, but the good wrench makes the line and fitting easier to reuse.I always break the fitting loose with a pair of Vise grips first. Then soak the fitting in penatrating oil. Slowly work fitting back and forth to loosen rust between fitting and tube. Take your time sos not to twist off the tube. On severly rusty lines remove bolts from cylinder then turn cylinder holding fitting with Vise grips. A little time spent at the begining will save you from replacing the hard lines.
