Old February 14th, 2008, 15:49
Jeff1's Avatar
Jeff1 Jeff1 is offline
Coolant temp sensor
Maybe I'm missing something, but I don't have a coolant temp sensor on the left side of the block, in front of the block drain plug like the service manual says I should. I only have the one in the thermo housing? Anybody have a clue? It's a 95 with a 4.0
Old February 14th, 2008, 15:52
JeepinCoastie's Avatar
JeepinCoastie JeepinCoastie is offline
Re: Coolant temp sensor
are u talking about for your gauges?
that on the back of the block
Old February 14th, 2008, 15:56
Jeff1's Avatar
I know one's for the computer(assuming its the one in the thermo housing). The service manual shows the other on the left side of the block just in front of the drain plug.There's a plug there but no sensor. I'll check in the back of the block. Thanks.
Old February 14th, 2008, 16:00
yea i dont know about that one ... the only one i can think of is on the top on the back of the block drivers side
Old February 14th, 2008, 16:10
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
The one at the back of the block is the gauge.
The one in the t-stat housing runs your computer etc.
The Renix years had it in the side of the block.
Is the manual for your year??
Old February 14th, 2008, 16:14
Jeff1's Avatar
Is the manual for your year??[/quote]
Yep, it's a 1995 service manual
Old February 14th, 2008, 17:23
techno1154's Avatar
techno1154 techno1154 is offline
Yep, it's a 1995 service manual[/QUOTE]
The 1995 year model uses the DC ECM not the Renix. They do not have the sendor/sensor in the side of the engine block under the exhaust manifold just 2 drain plugs. The sendors for that year model are:
1) in the thermostat housing. That sends signals to the ECM.
2) in the back of the cylinder, drivers side. The signals from thet one goes to the in-dash guage.
I think the Renix model ended in ???1991/ 1992. (not sure)
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old February 27th, 2008, 19:40
spike8152's Avatar
spike8152 spike8152 is offline
Anyone have a part number for the gauge sensor?
And a more detailed decription of where it is cause I am blind and can't find it.
Thanks
Old February 27th, 2008, 20:51
ParadiseXJ's Avatar
I believe 90-91 was the crossover. At least I've seen closed cooling systems on both years but no open systems on 90's. As far as sensors, I dunno.
XJ Coolant Temp sensor jfiscus OEM Tech Discussion 6 January 28th, 2008 12:13
Coolant temp. sensor? TBLimited OEM Tech Discussion 16 February 15th, 2005 07:18
Coolant temp sensor CutLaredo OEM Tech Discussion 5 November 21st, 2004 13:21
Coolant Temp Sensor saint_raider OEM Tech Discussion 5 June 22nd, 2004 18:33
Coolant Temp. Sensor Xtreme XJ OEM Tech Discussion 8 June 30th, 2003 17:16
