Old June 8th, 2005, 17:41
Storydude Storydude is offline
Coolant Temp Sensor causes High Idle RENIX?
Hi all. Just trying to figure out this high idle problem.
88 MJ RENIX 4 cyl. 4 speed.
Replaced the Intake/exhaust gasket because it was toasted, Idle came down about 300-500 RPM.
When it's cold, it idles right at 750RPM. As it warms up, idle keeps climbing, untill it's around 2500-3K at fully warm. Idle Speed motor is working, and adjusted correctly. I tested the CTS, and it's cooked. All new Vac. lines, and no leaks around intake, or TB. Throttle plate is closed all the way.
Will a Blown CTS cause a rich running condition, and high idle???
Old June 8th, 2005, 18:14
rockwerks's Avatar
rockwerks rockwerks is offline
Re: Coolant Temp Sensor causes High Idle RENIX?
might but my quess would be the map senser, if you rev the motor will the idle come down?
Old June 8th, 2005, 18:18
Nope. And MAP sensor tested within spec.
That's the ONLY sensor that's bad, and I'm wanting some background before dropping 25 bones on a THERMOMETER. Other than the high idle, it runs GREAT....but I want to fix it before I melt my new Clutch because of the high idle. It'll lope along at 45 in 4th with my foot off the gas.
EDIT: I went out and re-torqued the intake, all were where I left them. sprayed Carb cleaner around the intake, and no change in idle speed, so there is no leak there. I removed that big Black Vac. Block to the left of the TB, and ran ALL new lines to replace it. New TB gasket, and no Vac. Leaks I can find.
It seems like an old Carbed engine when the choke sticks..
Old June 8th, 2005, 19:34
georgemu georgemu is offline
Unplug the CTS and jump the plug with a resistor, RadioShack?, and see if it helps.
I'd pick a value for 190 to 210 degrees F.
Go here for resistance / temp values:http://www.angelfire.com/my/fan/CTS.html
Let us know.
Coolant gauge reading low... rough idle.. 4.0 Talyn OEM Tech Discussion 3 December 3rd, 2004 08:56
very high idle Mudskipper OEM Tech Discussion 6 October 24th, 2004 20:33
High Idle - After Driving; Weird TPS... LynchMob OEM Tech Discussion 5 November 10th, 2003 17:41
Idle is high on 4.0l 88justin OEM Tech Discussion 6 April 14th, 2003 15:15
high idle problem frsno jeeper Sierra Chapter 6 January 12th, 2003 12:33
