Old April 9th, 2012, 21:48
AnthonyZ28's Avatar
AnthonyZ28 AnthonyZ28 is offline
Voltage problem with coolant temp sensor.
I have a error code #22 thats causing my check engine light to be one. Code #22 is the coolant temp sensor is recieving too much or not enough voltage. Today I replaced the sensor itself and the code was still there. The thing still drives like a champ but the check engine light bothers me. Im not quite sure how to resolve this problem.
Old April 10th, 2012, 08:03
whitexj98 whitexj98 is offline
Re: Voltage problem with coolant temp sensor.
Its not thats its recieving but that it is returning to high/to low... to low is below .5v, to high is above 4.5v need to figure out which one it is high or low... this can be done with a DRB or by backprobing... also need to carfully inspect the wires as far back as you can.
Old April 10th, 2012, 15:18
AnthonyZ28's Avatar
I drove it to and from school today and the light was off. So hopefully that was my problem.
Old April 11th, 2012, 07:22
bmsmalley bmsmalley is offline
are you talking about the sensor that is on the back of the head? If so, I broke mine off while trying to replace it. Do you know if there is an alternate location I can install the new one....getting whats left of the old one out is going to be a PITA.
Old April 11th, 2012, 18:22
ca_digger's Avatar
ca_digger ca_digger is offline
bm i have mine in the water neck in front alot easier to change out
P0117 Coolant sensor low voltage CEL alaskan OEM Tech Discussion 11 January 22nd, 2010 20:51
Coolant temp. sensor RyleyF OEM Tech Discussion 8 July 14th, 2008 11:35
Engine Coolant Temperature Circuit Sensor Low Voltage 98XJSport OEM Tech Discussion 15 February 15th, 2007 07:52
Coolant temp. sensor? TBLimited OEM Tech Discussion 16 February 15th, 2005 08:18
Coolant Temp. Sensor Xtreme XJ OEM Tech Discussion 8 June 30th, 2003 18:16
