- Westminster, SoCal
96 or 97? I was pretty sure it was 97 but I had some people claim that earlier ones had it as well
That;s what I thought.Yucca-Man said:97 with the new body style.
Before they were fiberglass. Are you sure yours is metal?BlackSport96 said:what were they before? Mine's a 96 and its definitely metal. Aluminum maybe? Is the steel stronger?
Never said it was steel, I figured mine was aluminum if it wasn't steel. Besides, did they even change the hatch (besides obviously the fiberglass to steel switch). I guess I'm just not as knowledgeable as you ATL.Atl XJ said:My '95 is definitely fiberglass. Think about it, why would they develop a steel hatch to use for one year knowing that a new body style was coming out the next year?
Your only 2 choices are steel or fiberglass.BlackSport96 said:Never said it was steel, I figured mine was aluminum if it wasn't steel. Besides, did they even change the hatch (besides obviously the fiberglass to steel switch). I guess I'm just not as knowledgeable as you ATL.
Kejtar: No, I'm not sure, it just feels pretty solid so I assumed it was metal.
Haven't used a magnet on it Intrepid, but that wouldn't have made me think it wasn't metal, if I rememebr right, aluminum isn't magnetic. I could be wrong on that. But I'm gonna go with the knowledge that its fiberglass based off the large response
copperhead said:The front surround is also fiberglass on the 96, did they change this as well on the later ones?
Copperhead
Yes, there is a design change, smooth edges, rounded, etc... and it's is a different shape on the bottom to fit around the new-style tail lights.BlackSport96 said:Besides, did they even change the hatch (besides obviously the fiberglass to steel switch). I guess I'm just not as knowledgeable as you ATL.
Churchlady said:I found out about this in a humiliating way. I bought a flag magnet to put on my hatch & when it wouldn't stick I took it back to the store & told them it was defective. They put it on their metal file cabinet & it stuck. The manager asked me what kind of car I have & laughed when I told him. (He has a '93.)
They look like metal & feel like metal--better, maybe. Have there been any long-term durability problems w/them? Are they harder to repair if damaged?
AZ Jeff said:The fiberglass hatch on the XJ was chosen by AMC when the designed the XJ for several reasons:
1. lighter hence better fuel economy (compared to a steel equivalent)
2. less prone to corrosion, which is a chronic problem on tailgates/hatches in the "rust belt" of the US
3. less costly tooling than the equivalent stamping dies for a metal hatch (this was probably the MAIN REASON, as AMC was not very well capitalized, and tooling is capital intensive)
