NAXJA is having its 18th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
It's not when did the non-vacuum front axle start, but when did the vacuum axle stop. The XJs with Selec-Trac have always had non-disconnect axles, beginning in 1984. The disconnect axle was only used with the Command-Trac transfer case. The last year they used the disconnect was, IIRC, 1990.
