    More Information - Join/Renew
Blower's blowing, but's not blowing....huh?
mhopton
Marietta, GA
OK, have searched and read and have narrowed this down.
- It isn't the blend door - I have very cold, or very hot air - when it's blowing.
- It isn't a vacuum leak - I have air blowing at all of the correct positions, feet, vents, defrotst, etc, when dial is turned.
Essentially, sometimes, when the fan speed is on 1, or 2, or 3, or even 4, I get very little air movement. I can hear the blower blowing like crazy up/down as the fan speed dial moves about, but sometimes, just no air.
Can this be narrowed down to the heater resistor under the dash on the passenger's side? Or, something else?
It *seems* to get better when I flip the temp control from hot to cold, but I'm not for sure.
BTW, 99, auto, 4.0l, 4x4, 90k. All stock.
thanks
The resistor just makes the fan speed change. And is completely bypassed on high speed. Don't know why fan would make a lot of noise like it is blowing, but air not come out anywhere.
No, coming out all the correct places, which I'm sure eliminates a vacuum leak. Just minimal blow at each fan setting. High works well though, which is why I think it may be the resistor at the passenger side foot well.
For a bad resistor block, the blower motor will generally work only full blast/high. Turning the switch through the different settings will make NO difference.
If that is the case, suspect the resistor block.
With minimum output at the lower fan settings, your problem may be the switch itself
But if the blower motor rpms go up and down as you move the heater switch, but air movement/output itself varies, I think I'd start looking at the blower motor.
But blower volume must be directly related to blower rpms unless the "squirrel cage" is spinning on the motor shaft or blocked by something. And if it spun on the shaft much, it would bind up pretty quick.
And the resistor either works or it doesn't. The thermal fuse blows out and takes out all speeds but high.
I agree with the previous post i wave seen the blower wheel strip out on the shaft of the blower motor and not want to spin but if thats the case it will eventually stop working.
Is it coming out the wrong vents, like the defroster or floor instead of where you are expecting?
not to hijack this thread or anything :pirate1:, but I have this problem as well and the air does come out of the wrong vents...I'm thinking its a vacuum leak but am open to suggestion...
Probably a vacuum leak or one of the air doors came disconnected from a cable actuator.
As for the OP's problem... maybe something stuck in the ducts blocking the airflow? Maybe the motor shaft stripped out of the blower fan? Maybe the blower motor is actually going really slow, but the brushes are grinding or the windings are humming angrily due to overcurrent from the motor going slow, and it sounds like it's going really fast?
Default mode is defrost. So with no vacuum, you get defrost. With too little vacuum, you might change to defrost under heavier acceleration.
Thanks for the posts and information. I'll pull the resistor and check it but it sounds like maybe I just need to swap out the blower motor. The output is in all the correct places and at the correct temp, it just doesn't...well, put out. We all know that is NO good!!
I fixed one where the squirrel cage was spinning on the motor shaft.
I've had some weird occasions where this would happen, and if I turned off the blower and then cycled the vent/outlet control the air flow would be restored. Always figured it was a vacuum motor sticking.
