Old September 3rd, 2017, 11:11
EMSJEEP's Avatar
EMSJEEP EMSJEEP is offline
Re: No Start after a year off
New camshaft sensor did it. She runs, but maybe not so well.
Old September 3rd, 2017, 23:19
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Put some 'HEET' in the fuel tank if been sitting.
Top of fuel and run it.
Sent from my SM-N910T using Tapatalk
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old September 4th, 2017, 05:51
ehall's Avatar
ehall ehall is offline
Injectors are probably gummed up. Lucas fuel cleaner does a good job if you want to go slow. You could also spray some carb cleaner into the rail, disconnect the coil wire and crank for a while, probably want to pull the injectors out of the manifold for that which means new o-rings too
my '91 beater rebuild
Old September 4th, 2017, 21:47
EMSJEEP's Avatar
Running well on some fresh gas now, the big problem was the arching spark plug from my parallel thread.
Thanks for everyone's help!
Old September 9th, 2017, 08:55
EMSJEEP's Avatar
So it looks like part of my problem is that I'm getting 4v from my 170 amp Powermaster alternator. How could the entire vehicle be completely shot just from sitting for a while, this is starting to get ridiculous. Last week after I got the fuel pump in, I charged the battery and ran it for a few hours, so I think this may be a new development...
Old September 9th, 2017, 19:14
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Alot is dependent on the relative humidity of the area that it was stored. When i stored Buster every summer in my garage, I was guaranteed to need to machine the brake rotors and drums. And that was technically indoors! A year is a long time for crap to deteriorate. I tell my customers to drive a vehicle once a month on the highway just to maintain roadworthiness.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old September 10th, 2017, 22:22
EMSJEEP's Avatar
That's fair, my brakes are totally toast, didn't expect any less, I dunno, it looks like it's running yet again at this point but it's one glitch after the next. It's on a small island with a lot of salt in the air, but I couldn't have imagined the destruction from rodents and to sensors.
Old September 11th, 2017, 19:47
four_shot's Avatar
How 'bout it Gonzo
Small island. What else are the rodents gonna do. They're too short to wheel the truck
4shot
Still no start, after a year. MountainRhino OEM Tech Discussion 12 January 31st, 2012 21:37
which year did steel hatches start? Kejtar OEM Tech Discussion 31 July 20th, 2004 15:46
non-vaccum front end, What year did they start? isaacson OEM Tech Discussion 1 June 29th, 2004 12:37
What year did they start useing the 8.25"? 88woody OEM Tech Discussion 6 April 28th, 2004 19:57
Which year did 8.25's start to have 29 splines? telemike OEM Tech Discussion 1 July 23rd, 2003 05:56
