what causes the leaves to spread like this?
Rainman
what causes the leaves to spread / shift like this?
they are 3.5"RE with boomerang shackles. sits at 5.5"
Mostly the lack of leaf spring keepers, and/or loose u-bolts.
The cause is flexing of the packs, the axle tends to "yaw" as you flex one side. The only real concern is with the backspacing of the wheels.
You need some leaf spring keepers. This is quite common.
