I'm also running 8.8 disc brakes with wj front brakes. Still using the stock booster and master. Only thing I have done is pull the prop valve o-ring to even out the braking. Will lock up 35's and has good pedal pressure. The pedal shouldn't be bottoming out mechanically at all.
What year model xj?
