HELP -Tranny cooler install - '00 Cherokee
I searched the threads, but still need a little help; the cooler is mounted, but I need ideas for lines routing.
Is the line routing the same on my 2000 cherokee as on the earlier ones? From the other posts that I have searched it appears that the top line into radiator is from tranny and the bottom line out of radiator is to tranny (cool).
The tranny lines on mine have some small sections of hose with the rest tubing and the lower connection out of the radiator appears to be a snap type fitting. The adapter sent with the cooler wont work on this type of fitting even if I could reach it!
Is there any alternative to just cutting the rubber hose in the return section and splicing in using double ended barb connections - I hate to create even more potential leak points.
Thanks,
QNJSXJ
Thanks,
QNJSXJ
