proper torq for a RE 5.5" long arm lift?
90Pioneer
USA
What is the proper torq specs for my rubicon express long arms and track bar?
I called rubicon express and they said "if the bolt breaks its too tight".
Start with the stock specs, a control arm is a control arm.
Torque specs:
Item .........................……......Torque Ft. lbs. .............. Nm
Lug nuts (1/2 X 20 w/ 60* cone) .... 85-115 .............. 115-150
All tie rod ends .....................…..... 55 ...................….. 74
Steering (both ends) ..............…..... 55 ................….... 74
Shock absorber upper nut .............. 16 ................….... 22
Shock absorber lower nuts ............. 17 ................….... 23
UCA frame end .....................…...... 66 ..............…..... 89
UCA axle end .........................….... 55 ................….... 74
LCA frame end ......................…..... 85 ...................... 115
LCA axle end .........................….... 85 ...................... 115
Track bar frame end ..............…..... 60 .................…... 81
Track bar axle end .................….... 40 ..................…... 54
Track bar bracket bolts ..........…..... 92 ...................... 125
Track bar bracket nut .............….... 74 ....................... 100
Track bar bracket support bolts ...... 31 ....................... 42
Hub bolts (3) ..13MM................…. 75 ....................... 102
Hub - axle bolt…36MM...........….. 175 ..................... 237
