AC nine
- California
Been stuck on this problem for quite a while now...fishing for some ideas.
Just installed the RE 3.5 lift with extended sway bar links and my sway bar links are not lining up vertically.
As in the drivers side is almost an inch higher than the passenger side.
Passenger sway bar link bolts on to the axle but then the drivers side link is short and does not reach the axle.
I installed the adjustable track bar and rotated the coils until they hit the stop.
I'm lost...
Do I need adjustable sway bar end links?
I've heard of jacking up one side of the axle to force it to reach, but wouldn't that put a preload on the sway bar once I lower it and drive?
Any ideas?
Thanks
I'm lost...
Any ideas?
Thanks
