Just tie rod
Partial Conversion
1 - DS1312 - Drivers side inner tie-rod at the drag link
1 - ES3096L - Left hand thread tie-rod end (this could be either left outside or at the pitman arm - they are both the same)
1 - ES2079S - Tie Rod End Adjustment Sleeve
Drag link and tie rod
Full Conversion
1 - DS1310 - Passenger, or right side, outer tie-rod (called drag link in some applications)
1 - DS1312 - Drivers, or left side, inner tie-rod at the drag link
2 - ES3096L - Left hand thread tie-rod end (this could be either left outside or at the pitman arm - they are both the same) YOU NEED 2 OF THESE!
