TJWAXJ
- Idaho Falls Id.
So I started my project last weekend, this is 92 xj, it already had a six in. rubi lift, long arm kit,etc. I am swapping in a Dana44 from a 77-78 ford f100. I thought and searched hard for ideas on how to do this, I concluded it would be really easy to reuse and modify the origanal mounts lifting it another 2 in. I am considering just using one of the upper arms and using it as a three link. any thoughts on that? I set my pinion angle at 6 degrees, I saw this mornig that it probably should be about ten :flamemad: Now I guess I need to cut it out and move it another 5 degrees. As soon as I get it rolling I am starting on the rear d60, I wonder if it should be ten degrees also? Why the hell can't I post attatchments?
