Old October 28th, 2006, 00:22
vintagespeed vintagespeed is offline
Dana 30 stub axle THREAD size?
Anyone know what SIZE (metric) the thread is? I know the pitch is 1.5 but what's the diameter?
Old October 28th, 2006, 04:06
RCP Phx RCP Phx is offline
Re: Dana 30 stub axle THREAD size?
In the original lookup it said 24x1.5mm
Attributes:
Additional Contents:Cotter Pin & Washer
Hex Size:36mm
Thread Size:M24-1.5
http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=6 301600&Description=Spindle+Lock+Nut+Kit
Old October 30th, 2006, 12:31
k, thanks!
1990 ABS axle stub & tone ring needed lawrence OEM Tech Discussion 0 October 9th, 2006 13:20
Dana 44 axle shaft nuts/diff cover bolts....size HeavyMetal OEM Tech Discussion 0 February 27th, 2006 13:33
Are dana 44 stub shafts and hubs universal between different makes of vehicles? Big Red Modified Tech Discussion 12 August 15th, 2005 13:35
New! 297/760X inner/outer stub axle pass side JET455 For Sale: Private Party Only. XJ ITEMS ONLY 0 January 24th, 2005 07:55
thread size dogtired OEM Tech Discussion 13 June 8th, 2004 18:59
