Old October 8th, 2006, 09:24
iBran iBran is offline
Replacing thermostat -- drill holes?
My 1994 4.0L has been running cold lately. It eventually warms up to "normal" (around 210 on the gauge), but during highway driving it hovers around 130-155. Sure, the gauge/sensor could be wonky but I'd rather be safe and just replace the thermostat.
I searched the threads here for some tips and noticed that a lot of the guys with the old RENIX (closed cooling system) 4.0s recommend drilling a hole in the thermostat to allow air to pass through. Is that necessary on my '94 with the open system? The thermostat I purchased has no such holes.
Old October 8th, 2006, 11:14
jeepdude10000's Avatar
jeepdude10000 jeepdude10000 is offline
Re: Replacing thermostat -- drill holes?
no u dont need hole, the hole is to help get rid of air when first installed.
Replacing thermostat alpinetiburon04 OEM Tech Discussion 3 April 10th, 2006 13:28
Drill out or cut off? imma honky OEM Tech Discussion 23 June 13th, 2005 09:23
Replacing my Water pump and thermostat, couple questions? HEX-J OEM Tech Discussion 14 August 27th, 2004 21:00
12V drill Kejtar Non-Tech / Off Topic 11 June 25th, 2004 16:35
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
