Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old September 3rd, 2017, 14:23
Sub Zero Sub Zero is offline
Drill and tap thermostat housing?
I'm been looking for a solution to add a threaded temp sensor for my taurus fan swap as I'm not very fond of the radiator probe type. I came across a "high flow" thermostat housing made by hesco that has an extra temp sensor hole. I don't really need or want anything "high flow" since my jeep has no issues with running hot or overheating. From what I can tell, it's just a factory housing that has been modified. Has anybody has any luck drilling and tapping their thermostat housing with any success? I've posted the link below so you can see the extra hole drilled and tapped in the housing face. I also tried searching but I can't get it to work on mobile.
http://www.hesco.us/shop.asp?action=...8&header=false
Old September 3rd, 2017, 14:53
Jeep Driver Jeep Driver is offline
Re: Drill and tap thermostat housing?
https://www.summitracing.com/parts/b...Ap74EALw_ wcB
This one comes with a ground stud, you will otherwise need to find the correct 2 wire that will cycle at the correct temps. You'll want one that comes on at 195.....any later and you'll be catching up and running hot.
The Hesco is BS, try finding a good switch with 1/4 npt and the correct cycle temps.
Old September 3rd, 2017, 15:08
RCP Phx RCP Phx is offline
That's where the temp sender is on a late model!
Old September 3rd, 2017, 15:25
I looked at those as an option too and may use one as a last resort. I just thought it would look a lot cleaner to mount it on the housing instead 9f having to cut a hose. Also, the fan controller I'm going to use is fully adjustable and comes with the sending unit.
Old September 3rd, 2017, 15:10
lawagoneer lawagoneer is offline
Drilling and taping the housing isn't difficult. Make sure which threads you need for the sensor as most are NP and not a SAE. If it is NPT don't get crazy with the tap as NPT is a tapered thread, go to far and the sensor won't seal. I do it to and temp sensors to older boat motors all the time, that's how I know about getting out of control with the tap.
Old September 3rd, 2017, 15:31
Yeah the sending unit is 1/4x15 not. I know that the threads taper to help the connection seal.
Old September 3rd, 2017, 16:18
Originally Posted by Sub Zero View Post
Yeah the sending unit is 1/4x15 npt. I know that the threads taper to help the connection seal.
Old September 4th, 2017, 17:22
iwannadie's Avatar
iwannadie iwannadie is offline
The Hesco housing is rather nice. They just cut away some of the restriction inside, a little more flow will never hurt.
97 Country 4.0 auto 4x4(231) 31s
Old September 13th, 2017, 08:34
RNMedic's Avatar
RNMedic RNMedic is offline
NAXJA Member #659
pretty sure the newer model housing will work with the correct adapter for the sensor. I did that on my 88. threaded adapter from Lowes, Home Depot etc
multiple Jeeps
currently 2001 XJ with stuff done.
Old September 16th, 2017, 12:44
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
I believe thet are talking about an additional spot for a sensor.
Otherise I would have mentioned that.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old September 13th, 2017, 20:21
ehall's Avatar
ehall ehall is offline
The stock housing has a little flat spot on the front that is perfect size for 1/8 NPT sensor. That is where I have the gauge sender
my '91 beater rebuild
WTB: Thermostat housing '95 H.O. BJL913 Colorado For Sale/Wanted Forum 3 December 7th, 2011 05:23
thermostat housing help!! CBB311 OEM Tech Discussion 10 January 22nd, 2009 21:18
WTB thermostat housing Israel InterMountain Chapter For Sale/Wanted 3 September 9th, 2008 04:51
thermostat housing 4.0L dude in an xj For Sale: Private Party Only. XJ ITEMS ONLY 0 May 30th, 2007 17:24
Replacing thermostat -- drill holes? iBran OEM Tech Discussion 1 October 8th, 2006 10:14
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
