2000Cherokee
- mass
well i am looking at getting a welder but i would like to keep the cost low. i found one at home depot and it s lincoln..
here are teh specs
Versatility, value and dependable performance are the hallmarks of this terrific wire feed welder from Lincoln Electric. You'll be welding with gasless, flux-cored wire on light gauge mild steel in no time - everything you need is right in the box! The Weld-Pak 100HD has 30-100 amps welding output and welds up to 1/4 In. steel. The welder plugs into a 115V (15 amp) outlet. The unit is compact, portable, lightweight and easy to use. The Weld-Pak 100HD comes with a 3 year warranty on parts and labor. (90 days warranty on the gun and cable).
• Easily upgrades to MIG
• Welds up to 1/4 In.
• 3-year parts and labor warranty
• 90-day gun and cable assembly warranty
and i can get the gass conversion kit for it. for an extra 100 bux. i am looking for something i can do to fix body panels, weld on new spring perches and weld on a new body mount on my cj. do you guys think this would be a good welder for me? this will be my first welder.
here are teh specs
