Old November 12th, 2017, 05:56
Intellect Intellect is offline
Re: Weird rattle from starter/transmission area
Originally Posted by cruiser54 View Post
If this happens, you should remove them one by one and reinstall the bolts with Loctite.
They will likely loosen up again at some point otherwise.
I plan to. It was 1am and i had an event to go to the following day
Sent from my Moto G (5S) Plus using Tapatalk
Old November 12th, 2017, 05:58
cruiser54's Avatar
cruiser54 cruiser54 is offline
Gotcha. Just making sure folks are aware of that. Have a safe trip.
Old November 12th, 2017, 06:38
Thank you, i hear the bolts are a pain to get out. True or not too bad?
Old November 12th, 2017, 06:43
cruiser54's Avatar
Easy. One at a time.
Old November 12th, 2017, 18:13
blakews2217 blakews2217 is offline
Iíve had them back out so far as to sound like a rod knocking away. I pulled the cover and they were out 2 turns. Locktight and plenty of torque and havenít had an issue
Old November 14th, 2017, 20:33
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
As this topic progresses, I'm uncertain about my cat rattle diagnosis, and think it might indeed be loose converter bolts.
I've ordered a set of the updated bolts, just in case. Looks like they have a broader head for more clamping area...?
Old November 15th, 2017, 04:50
cruiser54's Avatar
I really think it was an issue with the LocTite they used and/or the torque spec.
Old November 16th, 2017, 00:05
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
If you tap hard enough or pound on the cat (that's what she said), and it makes noise then that helps narrow that down.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old November 17th, 2017, 10:42
greenlawnjeeper greenlawnjeeper is offline
Glad its fixed. My rattle under there was the 4wd linkage which was cured with alot of spray lithium grease.
Exhaust Rattle after replacing Transmission Mount Nacho-1990 OEM Tech Discussion 9 September 11th, 2015 23:25
Rattle from transmission? 98cherokeedriver OEM Tech Discussion 2 April 4th, 2012 10:36
Weird rattle in trans at startup! n9viw OEM Tech Discussion 9 October 30th, 2006 14:21
Steering area rattle? GudaXJ OEM Tech Discussion 3 August 1st, 2006 09:27
weird alt/starter activity DeftwillP OEM Tech Discussion 1 February 2nd, 2005 16:11
