Old November 11th, 2017, 09:03
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: In-vehicle rod bearing/wristpin replacement?
That is a AMC document which means it might apply if you own a 84-86!
Those codes were used up until the end of 4.0 production.
Chrysler didn't toss a system they still used and in special engines still use.
All manufacturers have used or still use similar codes.
The ones that don't any longer are the ones that have fully automated engine production and toss out of spec parts instead of machining them to work.
Old November 11th, 2017, 09:15
RCP Phx RCP Phx is online now
Originally Posted by Jeep Driver View Post
As for welding up a journal? 4.0 cranks are still dimes-a-dozen, another dumb idea.
I've welded 1000's of cranks! It used to be a common practice specially for increasing the stroke!
300 bearing replacement MattK99 Modified Tech Discussion 0 September 20th, 2012 21:09
A/C Bearing Replacement jeepster_259 OEM Tech Discussion 28 October 30th, 2008 09:38
8.25 bearing replacement JohnJohn OEM Tech Discussion 11 July 10th, 2005 17:01
Bearing Cap Replacement LouisianaZJ OEM Tech Discussion 3 December 30th, 2004 22:45
NP 242 bearing replacement 8Mud OEM Tech Discussion 1 July 24th, 2004 22:35
