Old February 1st, 2007, 18:20
sprngfldxj's Avatar
sprngfldxj sprngfldxj is offline
Whining Noise??????
I started the old xj and it started to whine! The noise is located in the tensioner/waterpump/fan clutch area.
Unfortunately I cannot confirm with out the engine being on, and it is dangerous in there!
The noise changes in sound when the accelerator is applied.
Anyone have any defined ways to know for sure with out replacing the whole jeep???????
Old February 1st, 2007, 18:25
KarlVP's Avatar
KarlVP KarlVP is offline
Re: Whining Noise??????
You could take the fan off, put the bolts back on to hold the pulley on, and see if the noise goes away. If it did, it's your fan clutch.
Old February 1st, 2007, 18:37
xjfreak40 xjfreak40 is offline
you sure it's not just a sqealing serpentine belt?
Old February 1st, 2007, 22:00
sprngfldxj's Avatar
That is what I thought too.......the belt that is?
I sprayed something on it to lube it, but it remained.
I will try the fan thing
Old February 2nd, 2007, 14:39
Bradlybob's Avatar
Bradlybob Bradlybob is offline
Don't forget the idler pulley bearing.
Old February 2nd, 2007, 21:52
lawsoncl lawsoncl is offline
That was my first guess. If you have a length of hose, you can use it as a stethoscope to listen near the pulley (safer than a long screwdriver). You could also pull the serp belt and give things a spin.
Old February 2nd, 2007, 22:07
GoliathJeeper GoliathJeeper is offline
I had what was more of a squeak. Turns out the frontmost pushrod wasnt getting any ooil to the lifter. A fast way to see if it is even in your belt drive system is to just yank off the belt then see if it goes away or not.
whining noise Mikel OEM Tech Discussion 5 March 11th, 2006 13:04
Hissing/whining noise from HVAC ebxjbob OEM Tech Discussion 5 December 24th, 2005 08:38
Whining noise from motor jeepboy12001 OEM Tech Discussion 7 September 16th, 2005 21:43
whining noise, need help ASAP CStamm OEM Tech Discussion 7 October 20th, 2003 14:26
Engine Whining noise CStamm OEM Tech Discussion 6 September 29th, 2003 13:26
